Puller
Puller
Yup, a turbo is actual a turbine-supercharger. Pro-Charger is just a cold side of a turbo but belt driven although they tend to spin 50,000 to 100,000 more rpm's then a typical turbocharger.
I want to work it in reverse. have the largest Eaton supercharger M120(iirc) bring up the boost until a larger turbo that can handle the higher air volume can take over. i haven't had the time to really put anything together since all this is a mental exercise in the meantime, but the parts to make this happen do exist. All it needs is some serious time spent building brackets and plumbing.
That was standard fare on two-stroke Detroits when a turbo was added to the engine. However, the blowers on those engines weren't really super high-output units...they weren't meant to boost engine power output so much as they were meant to scavenge the exhaust gases out of the combustion chambers and get fresh air in there. Note that non-turbo Detroits are generally referred to as being "naturally aspirated" even though the superchargers are always present on 'em...a Detroit won't run without it!i know that some busses run this setup. a supercharger to get them going, then a turbo to take over. i always figured it was a waste on our trucks though.
What type of supercharger are you going to use? Roots (lobe type), Centrifugal (functions like a turbo only belt driven) or Lysholm (screw type). This would be the first question you have to answer. The second would be what kind of power are you looking to make (Really this should be first but you've already stated your going supercharger but this would help narrow down sizing)? I know you said you don't care but you still need to choose something that will run correctly and not cause problems. Once you've figured out what type of supercharger your going to use some suggestions can be made. What is your budget, this will determine what type of parts we can suggest you use.
I think the ratio on a procharger is a lot more than 4:1...
I just looked it up on their website, it looks like most of them turn around 70,000 rpms max. So probably more like 100,000 to 50,000 LESS rpms than a turbocharger. Still that's an awful lot of rotations for something belt driven.
Ok, now wait a minute. You are saying that a belt driven device is going to spin faster than a turbocharger? I 'm not buying it. Even at 4:1 overdrive, the belt drive is limited to the speed of the engine crank. So, at 6000 engine RPM, the belt drive is spinning at about 24,000 RPM. That isn't near 100,000 RPM. Turbochargers are not similarly limited by a mechanical drive system.
If I could draw whats in my head well...never mind that..
How bout twin centrifugal chargers one on each side of the front of the engine, two turbos one on each side at back or underneath truck...and one 871 roots blower ...the two centrifugal and two turbos all plumbed into the top of the 871 hell ya....seriously show quality...
One thing you did not mentions with all this ***** flowing through your thread....whats yer budget?
You're forgetting the gear/belt/planetary drive that's in between the pulley and the impeller. Yea, the pulley is only 4:1, but the drive section is another 4-6:1 on top of that.
Also, NO a centrifugal supercharger does not spin as fast as a turbo. It doesn't need to, they have orders of magnitude more torque available to spin their impellers. So they run order of magnitude larger impellers to match.
not enough...lol. but i have time and i can make all the custom pieces i need here at the shop no need to spend money on ordering special crap. so my only real expense would b the sc itself. and agin OLDSKOOL... no turbo
