73idi88f350
looking for tips for changing the clutch master cylinder
mines leaking into the cab and is now starting to cause problems with the clutch..
i already picked one up and it dont look hard. but looking for tips on removing the plastic line.. and should i try to bench bleed before installing looking for best ideas because i cant let the truck be down..
my idea for a bench bleed is to stick the tip down in break fluid and fill the res and try to pump it till no air, then put the plug back in till ready to install the plastic line..
