fiverpuller
Lizard Limo
Time for open air element...need intake hat!
Ok...I think I finally crushed the banks k&n to the point of not sealing. So it's time to junk the black box and go with an open air filter. Problem is the newer design has the intake hat casted into the filter housing. This is the biggest PITA since you have to line up the air in/air out hoses while tucking the big openning on the intake manifold. Anyway....I won't have an intake hat like the old style banks so what can I use? I think Mel mentioned the Hypermax will fit old non-waste banks? If so what's the part number and where can I order/buy one? Dare I ask how much?
I think I found the elbow and tubing to do the job. Is a 3" tube going to be enough? Also found a filter that flows at 900cfm...is that enough? I plan to put a filter minder on anyway to see if there is much restriction...new and as it gets dirty. Thanks!
