Wanderer-rrorc
did a tow lastnight with the van...
got 9psi boost (and got out of it!!..dont wanna blow the heads!)...and 935egt....doin 55 up a pretty good grade...on the floor!! and barely holdin 55...barely...
wife was following me..said it wasnt smokin bad at all...
best guess is I was draggin LESS than 5k...trailer weighs nothin..and my sploder is GUTTED out (read nothin but frame and outside skins..inside gutted like nascar body)...
time for an IP?? its got 144K.....got a receipt for IP at 75K..but nothin for injectors...
waday think?
EDIT EDIT EDIT!!!!!!
towd the explorer to the new house yesterday...I got problems!!
on one hill (long and sorta steep...but not THAT BAD...I got 10psi of boost..and the EGT'***** 1050....floored...and the temp rose from 200 to 230....
and thru driving it the last 10 miles...my temp rose to 240....and didnt really cool off till I turned on the inside heater...and it came back to 220 drivin the country roads.....I get into town on the freeway and its doin 220 and ok on the EGT's (550+-50)...and get off the highway and it goes back to 240...so I turn on the heater...drops...get in stop and go traffic for a bit...and it goes back to 250!...
could I be running too lean and causing the engine temp to heat up?? I dont see much white smoke...and I attribute it to the CDR mod that dumps into the exhaust...
oh..and remember fellas...my IP fuel screw is stripped...I cant get it to turn up..but now that I FINNALY HAVE A GARAGE again...I can work on it...unfortunatly the van is too tall to fit into it...dammit!
waday think?
