Ticking/clacking noise!?!?
Bootzz
Louisiana
Truck is runnin pretty good but has developed a ticking/clacking noise
It hits with the beat of the motor if that halps
Any thoughts?
Wyreth
Certifiable Noob
Las Vegas, Nv
what I would try, is first, loosening injector lines one by one to see if that changes the noise or makes it go away. Then I'd pull the valve covers and look for play in my valve train. (from the little info you posted, that sounds like you have a flat lifter, loose rocker, or bad valveguide)
Hydro-idi
Lodi, California
We need more information....like the age of your fuel injection system, if noise is evident when engine is cold/hot or both, what color exhaust smoke if any, things like that.
Kevin 007
Full-floater
Nelson BC Canada
Probably what Wyreth said, rockers, lifters or valve guide. But usualy you would notice an increase in noise over a period of time. Is that the case?
Hydro-idi
Lodi, California
IMO, the lifters tend to get dirty and/or wear out faster than rocker, pushrod, or valve guide complications.
Knuckledragger
Payson, AZ
Check oil level. I had a lifter/rocker arm click that developed after going 2 quarts low. If oil is OK, find location of noise by process of elimination. Crack injector lines, as previously stated. If not injectors, put a long screwdriver on the valve cover and your ear on the end of the handle. It will act like a stethoscope and let you know if there is a rocker problem (a stethoscope is fine, too).
Bootzz
Louisiana
It ran low on oil when I had the oil cooler problem
Since then it's been doing it
I've got oil now but it's tickjng
91idi
Fiberglass *****
X
Injectors can click. My 91's will if I don't put lubricant in the fuel
Bootzz
Louisiana
Sounds like when an ip is advanced to much buy I retarded it and no change
Hopefully ima get the donor truck this week and replace my power house
Hydro-idi
Lodi, California
A rod knock and an engine ticking noise are very distinct noises. If it is diagnosed as a rod knock, I would tear into it asap if you could. But if it is an engine tick like mine currently has, it is probably just a worn out lifter or two and there would be no need to put in another engine for that in my opinion.
crispy74
