It's not mounted solidly to the pin. Look at it and you will see.
They can be seated in their mounting "bracket" wrong and either not have enough pressure to keep the brake lights off, or can go the other way and not activate the brake lights soon enough. The switch can be moved a little in that mounting piece.There is no adjustment for the brakelight switch. It uses that hokey setup that Ford came up with years and ago and used on all their vehicles.
