gatorman21218
wouldnt it boil out of the fuel?
With all the issues of the 6.9 GP system I am surprised someone has not adapted a tractors ether ignition system on to one of these trucks. Like said earlier. a small can will last a LONG time if done properly
my 93 IDIt was a bottle baby. redid the GP system twice, and gave up on throwing any more money at THAT waste of time, and fed him a loving shot of "the juice" daily.
my current IDI, well, I didn't even hook the plugs up. Its a bottle baby. Only a pain in the ass when I have 6 starts in 12 hours with a small amount of run time apiece. However if the water temp gauge registers at ALL, 110 degrees for example, she cranks over and fires with no aid.
starting fluid is really ******* hood hinges/latches.
There is no such thing as addicted to either, or a "BOTTLE BABY" if you fix the glow plugs and have them working properly they will crank just fine, my engine spent 5 years being started daily on either by my father, it then sat around 10 years untouched, then i needed an engine so i got dads old truck out pulled the engine out fired it right up on either, i used either around 6 months, now i have only 6 glow plugs in the engine, and it fires up every morning on just those 6 glowplugs! yep she is certanly addicted to ether
You're right. Trucks are inanimate objects and incapable of addictions, physical or psychological.
Lemme type that twice w/o my typical light hearted facetiousness:
When I bought my 93, the glow plug system was inop. So I spent $100 on Autolites, give or take, and $120 on a relay from Navistar. Brand new truck for 3 weeks, maybe two, then a bit5ch again. SO I ohmed all the Glow Plugs.
2 ohms IIRC. So I bought a new controller from CSK or Navistar can't remeber which, and installed that.
Now we are in the system $350 and we start like brand new again. Shortly there after, I lost my GP system again. At that point, I re ohmed said Autolites, and found them to be 2 ohms IIRC, and disconnected them said Fawk It, and started the truck off Ether. I could have purchased over 100 cans for the money I wasted on the fawking GP system, and it was too cold out to spend hours under the hood chasing this bad ground, or that one, it has to be more serious of an issue than an inop gp system to get to work on the truck in the FAWKING winter... Gawd I hate winter.
So your right, there was a mechanical fail, and a Mechanic's fail.
Instead of the above soap opera, I chose to use the word addicted.
89% of the reason for the Ram Air it is getting is to avoid having to pop the hood every time I fire it cold on the current truck.
I always thought it would be cool to go to norther Canada in -50*C temperature and pour out propane, it would be a liquid, I think thats neat .
