TWeatherford
I moved this summer from Kentucky, elevation 547 ft, to Colorado, elevation 9,000 ft, finally to Arizona, elevation 7,000 ft. It seems to me my diesels (truck and TDI Jetta) were harder to start in CO and here as well. It wasn't as noticeable in the summer, as the difference between 2-3 revolutions and maybe 3-5 is pretty minimal. But we've been getting below zero here lately, and the difference seems bigger to me. I know atmospheric pressure is about 4 psi lower here, which is certainly noticeable in power and black smoke. I'm wondering if anyone else has had an opportunity to cold start at drastically different altitudes, and noticed the difference I have?
The Jetta has all the same parts between last winter in KY vs this winter in AZ. So they are a year older and more worn out certainly. Nothing is showing signs of failing, and the battery was replaced just before the 1st winter in KY.
The 94 Ford, in KY, started at -2 F (coldest it ever got) in just a few revolutions with a 16 second manual glow. This was with 4 year old group 65 batteries, corroded battery cables, and the starter that it came with. As soon as I moved to AZ, the alternator died and took the batteries with it. So it has a new alternator, I swapped in group 31 intersate batteries, new battery cables from custombatterycables.com including a 3/0 starter lead, and threw a brand new starter (can't remember what it is, it was recommended here), and it most recently has a new injection pump. I've checked that the glow plug system is in good shape, and it still starts, but not nearly as well. I'm going to blame altitude until someone tells me I'm wrong.
