This is also interesting
7.3 powerstrok
u.s.a.north
im going to try wmo how much kerosene would you add to 5 gal of wmo ?also have you ever used a self clean filter ?steel canaster with a handel on top drain on bottom it has a series of plates inside just a turn of the handle and its clean again .ill try to post some picts .
EMD_DRIVER
Say what?!?!
Beaufort, SC
I mix mine 1/3 kero and 2/3 WMO. That's for the 20w-40 oil I've been getting. You may need less kero, if you are burning a lighter viscosity oil. For 5 gallons, I would start with around 1.5 gallons of kero and see how thin it turns out. I'm not familiar with the type of filter you described. A picture might be worth a thousand words..
7.3 powerstrok
u.s.a.north
auto cleaning filter
here it is i think it filters down to at least 90? micron good for primary but you only need to buy one ,
pwillis
