rodman68
How do you tell if the viscosity is the same as #2 diesel after you are done?
I need more knowledgeable users to point out what i need to learn yet before trying in my jeep liberty.
"Does your pump self prime? If so any idea how far it will lift oil?"
this pump doesnt prime itself very well, this is why i had to use a gravity system and let the wmo drain down into the pump. this method solved my problems of trying to keep pump from cavitating. this pump will push a lot of fluid as far as you want to go... well over 200 psi, Be Careful! my centrifuge maker recommends 85-90 psi max. I use airhose lines rated for 300psi. I have not yet tried the wmo in my jeep diesel yet. still developing my system
Thanks!
PZ
emd driver are you running wmo in a psd ?
whats a po??? just to be clear you bought 9 (replaced )18 psd injectors failed because of running wvo
