In theory it's a good idea and I'm not bashing or anything, but practical application I'm not so sure without some Rube Goldberg kinda engineering
a 5/8inch connection to a source of crankcase pressure, (I welded my 3/4inch to the plate that covers the IP bolts onto it's gear) Short piece of 5/8inch vac hose, and a 5/8inch T hardly qualifies as 'rube goldberg engineering'
I could have it assembled for $5, or I could root around the shop long enough and find the parts I need.
Even without excessive crankcase pressure, pull the dipstick on most of these trucks and it's obvious there is some pressure behind it all. Factor in a CDR valve shutting at high rpm and you've got a pressurized container the crankshaft, rods, and pistons are struggling to travel through.
On the other hand, if there was a filtered breather on a valve cover and an evac system pulling on the otherside, that pressurized vessel is replaced with a very faint breeze through the crankcase.
A pressurized vessel also tends to keep things suspended in the air better, hence things like windage trays are used to keep oil solids from slapping around in the engine.
This will be an interesting thread no doubt
Apparently not.
Ohh well back to reading threads like "I wanna put two powerstroke turbos on YO" and "I can spin my ancient 1200lb diesel 4,000rpms, so I gots me a hotrod!"
Drew
