The Resurrection
Philip1
Northeastern Nevada
got the engine put together with .020 over pistons, ceramic coating on the pistons and flowcooler water pump
got the ac and heater box replaced due to the old one being burned
got the engine painted blue and black
decided I wanted to install some air bags in the rear
saburai
Looking good!
I really miss engine building...
I've got the same air bags on Raylan. I set them up for independent fill so that I could tailor the pressure for an unequal load if needed. I put the valve stems in the lower license plate holes with chrome caps. Easy enough to get to and imho, looks pretty good.
Philip1
Northeastern Nevada
My air bags will have onboard air and a dual valve setup in the cab. It'll also have an exhaust brake thats air controlled.
Philip1
Northeastern Nevada
got the turbo installed along with the accessory brackets.
started getting the core support and radiator installed also.
then got the downpipe installed with the exhaust brake as well.
Philip1
Northeastern Nevada
Making progress
got the core support painted, ac condenser installed, fenders mounted, intake and intercooler piping mocked up.
Lance
