On to the next, next issue, I checked the glow plugs while they were out of this thing and I found 1 that reads open and the other 7 have various resistance readings. I looked at the base and they are autolites so we will be replacing the entire set as they are needed in PA in winter and from research on the site I see Motorcraft plugs seem to have everyones approval. Today I gave a check to see if we were getting voltage to the plugs when cycling the key, I used Bat - for my ground and touching several connectors at the plugs found no voltage present. I do hear clicking which I assume is the glows turning on, but no power out to the plugs, so I'll assume the controller is bad. Is there a particular controller that gets a thumbs up?
