MtnHaul
I've been trying to time my pump using the Tech-Time 3300-S unit but no matter how the mag probe is positioned I cannot get a reading other than -20.00, which is an error code meaning the probe is positioned incorrectly or a connection is bad. I cleaned out the hole for the pickup and sprayed a dab of WD-40 in it and the probe seems to insert 'till it hits the damper and then I retract it just a hair but nothing has worked thus far. The end of the probe is clean, all connections look good, and I do get an accurate RPM reading from the transducer so I'm inclined to think the base unit is functioning properly.
The damper is relatively clean. No rust buildup or crusty crud. Just how clean does the damper have to be to get a reading? I assume the mag probe senses the groove across the damper and the base unit translates that signal--can a piece of magnetic tape be used? I lightly scraped and wire brushed the groove but still no reading. Any help is appreciated.
