Mounted my extinguisher in my cab today, I know I know....why when I am changing cabs in a while. Well it's a safety issue for me. I'm in a high fire hazard area, I have been 1st or near 1st on scene on a few accidents and subsequently pack a decent first aid kit too!
So how and where?
First where, I mounted it so it can be accessed from either door and grabbed quickly! Behind my transmission shifter in front of my seat.
HOW
Well this was both the easy and hard part by myself all in one!
First I laid out my location by placing the mounting bracket on the floor and marking the four holes with a felt pen,
Second I too a 5/8" hole punch, the type for gaskets etc and punched through as much vinyl mat and sound deadener as possible. I actually got lots of material out.
Third, Centre punch the floor pan so I can drill with my step drill.
Forth Drill out the holes accordingly to size my holes became 5/16"
Fifth, this is where it gets tricky, pass the bolts through the mount and floor! Now longer bolts would be better but I had these from a previous mount setup!
Here is my solution to my 5th step!
I took some rail iron I had floating around the shop, about near 3 feet and set that on top of my bolt with my wrench in place on the bolt head. You can see me pointing to this here, also notice the FE on the seat.
I had to support the opposing end so I blocked it up with a 4x4 after if slipped off the basket ball I previously used
Here is my close up of how well the wrench was held
I had to reach up above the transmission between the floor pan and transmission to put the nuts on wow tough!
Anyway, here is my end result with extinguisher mounted.
That bout sums up my setup.
I feel more comfortable knowing I've got something in case of fire that can be easily grabbed at any time.
Thanks for reading
Al
So how and where?
HOW
Thanks for reading
Al
