Well tomorrows list took a few days long to get to.
But, got the mod somewhat done. Photos to follow this evening as 2 sick little ones sitting on my lap under the weather this am is limiting my mobility.
I removed the vent assembly on the front tank and found that it was nothing more than just a vent. No check valve just adapting the 3/4" hole into the 1/4" vent tube.
the problem.
So for all ya here's how I finished this thing off temporarily.
I took a 3/4" pvc threaded/barbed elbow and threaded it into the grommet on the tank top and then place 4' of 3/4" heater hose on the barbed side and zip tied the hose to the fill hose. To keep the dirt and crud out (redneck) I used a kitchen faucet aerator nozzle with a screen... Of course the water saver disc was removed for better flow.
Works purdy darn good except I still can't go wide open fill yet. I will be replacinge the rubber fill hose with an aluminum tube to keep things from squashing down as the current problem seen. Then I will also be brazing a fitting on the fill neck as to keep things contained in the event of a rollover.
Fill time before mod....25 minutes for the front tank.
Fill time after mod.....5 minutes for the front tank.
