Ciulster
Hey all! Recently I bought a 1983 F250HD. It's a little rough around the edges but most things I have been able to solve on my own. I havent been able to drive it much since I got it as I've been changing up the meds and I've had this burning question about something I noticed when I was highway driving on the trip home after buying it.
Now to clear some technical junk up it has 3.54 gears in the rear. Supposedly it is a limited slip. If not we'll call it 3.55. But I don't know what the gearing in the transmission is. I know almost all T19's in the diesels came with the 4.02 1st but I know that the '83 year had a rare option for 5.11 gearing. And the gearing in this truck feels really short. Like 1st gear governs out at around 9 mph so there is a strong possibility for that.
With that out of the way. The issue. When I go to downshift into third it absolutely refuses to go into gear and grinds horribly. I can feel it pop against the gear but if I try push it in it just scrapes and chudders like mad. Mind you this was at 50 mph gearing down for a hill. And once this happens I am locked out of all other gears until I slow right down. But downshifts are smooth and work properly if I brake down to say 30 mph. It downshifts fine at that speed. Again this is only affecting downshifts into third. Upshifts into third are smooth as can be. So I dont know about syncros.
I hear about guys downshifting at these speeds all the time. So I don't know why my transmission dislikes going into gear at these speeds. So what do you guys think? Could this just be a case of me trying to downshift at too fast of a speed for the diesel? Is it a possibility my transmission ratios are shorter than everyone else's and I am shifting at too high a speed? Or do you think it could have been my relative inexperience with a diesel truck and going straight from a 5 speed sports car to a 4 speed diesel and expecting it to engine brake and downshift the same caused it to not want to go into gear? Or is this a more serious transmission problem?
Any insight would be appreciated.
