T-19 yolk torque?
Austin86250
idaho
Looking for the torque spec on a 2wd t-19 output yolk
Internet and searches are not of use
rreegg
IDI n TDI
Puget Sound
For the retaining nut? This is Haynes
FrozenMerc
SW Missouri
What size is the threaded output shaft?
If 5/8" - Fine Thread, 180 - 200 ft-lbs should be close.
If 3/4" - Fine Thread, 320 - 350 ft-lbs should be close.
This is based on a standard high strength fastener, k factor = 0.15 to 0.17 to get to 80% of proof load.
I just did the output yoke on my ZF 5 a couple of weeks ago, but it was some metric size shaft and nut. 200 ft-lbs per the manual for that unit.
Gerhard
