hesutton
The Anti-Anderson
The top of the ZF5 made contact with my bullnose floor pan.
With a body lift it might clear but the bullnose boot would have to be made to work with the larger diameter ZF shifter. Otherwise, I have no idea how his bullnose pan fit over the ZF. I had lots of pics of this on webshots, but that has been dead forever.
If I have time tomorrow I’ll see if I can find those pics and post them.
Shifter for the T-case does not go through the pan on ZF trucks but the drivers side of the trans tunnel. So that’s why you’d need to cut the ZF pan for the T-case shifter on a bullnose. There is no t-case shifter opening on the ZF pan.
The mount boss isn’t the difference between the two transmissions, the shifter is. Different shape/bend. The bullnose t-case shifter works just fine on the ZF, but you have to make an opening for it in the ZF pan.
Heath
Heath
. I found that there are always variations. In my conversion to zf5 I used part of a cross member from one truck and part of it from another. Two pieces from two different trucks that used existing holes but one piece kind of swerved an inch either way as I recall. Same driveline.
