T-18/T-19 slave diffs
Chuckdiesel
Virginia Beach,VA
I am replacing my tranny and I found a T18 but it has an inside slave! I never heard of that but I think I can swap the guts and make it work has anyone ever hear of doing that and is an inside slave common on the t-18s?
RLDSL
Diesel fuel abuser
Arkansas
Is there a brand name on the thing? It may be a speed shop mod.
82F100SWB
Sioux Lookout, Ontario,CA
A concentric slave on a T18 is not a Ford thing. Only the small block 5 speeds ran that setup. The 4 speeds all ran an external slave, the small block one is smaller than the 460/diesel one, but still external nonetheless.
I'd be curious to see that internal setup on the T18. It's probably some sort of aftermarket setup.
Chuckdiesel
Virginia Beach,VA
Well it came out of a 460 truck that was wrecked. Can i use a T-18 I just found a reman for 400! on CL!
I dont know whats up with it I thought it was odd?
RLDSL
Diesel fuel abuser
Arkansas
The bellhousing isn't going to match up . If you have a t19 bell, I *think* it will fit, but don't quote me on it.gasser bellhousings won't work on diesels.
82F100SWB
That is quite odd... Obviously not factory, a factory 460 truck should be a T19 with the same hydraulics as an IDI.
A T18 or NP435 from a 4x4 ford will work as long as you have the diesel bellhousing, personal preference would be to find a T19 to keep the synchronized first gear though.
