syncros, forks, bearings, and seals?
Rawpower
'Froading Freak
Rep. of TEXAS
How mush sould all the synchros, all the shifter forks, all the bearings, and the internal seals cost on a 93 ZF-5 (should be an S5-42, not a 47 right?)
Searched for the parts, couldn't find them anywhere...
Thanks for your help in advance.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Yes, it'll be an S5-42. The S5-47 was used behind the PSD.
If I remember right, the kit to do mine was a couple hundred $$...but I really don't remember. Hopefully someone who's done this more recently will be able to tell for sure...
Pipeliner_86
IDI up high
Longview, Texas
Hey Rob, ya finally fabbed up your own reverse shackle kit. I think this got discussed over at the diesel stop months ago. You were looking into buying a kit, I said build one like I did. Looks good!
Rawpower
'Froading Freak
Rep. of TEXAS
hahah thanks... yeah it took me forever to jump on that boat. only took about 10 hrs to fab the entire thing... did you fabricate your own shackles too?
Pipeliner_86
IDI up high
Longview, Texas
Yes and no....the shackle mounts on the front of the frame are oem parts cut and re-welded, the rear shackle mounts is a kit from TSC that is intended for trailer spring shackles. My front frame-work is built out of 1/4 thick, 4" C-channel, and I used 1/2 plate to make the rear shackle supports where they bolt to the frame. I put 4" lift blocks under the rear axle.
Actual fab time was about 6 hrs. worth, the majority of the time-work was measuring and figuring things out.
It definately improved ride and body roll.
Jeremy.
Rawpower
'Froading Freak
Rep. of TEXAS
Here's what I did.
http://www.supermotors.org/vehicles/registry/showmedia.php?id=308258
http://www.supermotors.org/vehicles/registry/showmedia.php?id=309071
How long have you run the stock shackles in the rear? For off-roading, I was affraid I would fold mine over if I ran the stock shackles, so I (over)built some of my own:
http://www.supermotors.org/vehicles/registry/showmedia.php?id=318762
So basically I fabbed my own front hangers and shackles, using the stock rear hangers for the shackle mounts.
Are those your stock leaves?
Pipeliner_86
IDI up high
Longview, Texas
I built my shackle system last year in July. The stock rears have worked just fine, but I don't off road my truck....so to speak. The only off-roading it see's is when I run through the fields at the farm or go back to the woods to cut wood. I don't go looking for mud hole's. 10 years ago I'd be the first one in a mud hole, now I don't want to tear up my trucks like I used to.
Yes they are all my stock leafs. I added one, each side in the front.
Rawpower
'Froading Freak
Rep. of TEXAS
Yeah i'm just an immature 18 year old who blows it all on his truck just so he can break it better the next time... hahaha. oh well, I know its true.
Your front leaves just look like they have a lot of arch.
BTW, I am in love with your front clip/grill style. Those years were my favorites.
