junk
Well I've been getting to this point for a while. I have a 1993 F250 truck in my sig that is getting an engine swap. I'm swapping the engine because it burns 1 gal of oil to 120 miles. There is also now a constant blue cloud out the exhaust. Also the DMF is on it's way out. I bought a really good running used engine to swap. I believe the engine I bought had been rebuilt.
I don't want to a dripping pig so I've been resealing everything on the old engine. Oilpan, front/rear main seals, valvecovers, valve stem seals, etc. I also did a water pump and will be swapping over the new fuel system and glow plugs from the old engine.
I also picked up a NOS factory ford turbo for this truck off ebay. I'm also putting in a new exhaust system with 3" downpipe and 4" exhaust. I'll have to modify the factory exhaust outlet to accept the 3" downpipe. The downpipe and exhaust flange are my only real bits of fab on this. Everything else should be bolt in.
Who ever designed the mounting location for the 4 bolts that hold the turbo to the up pipe is a *******. The turbo took probably 2 hours by itself to remove. I wasn't sure I could pull the engine with it still on so I pulled it in the truck.
So far I'm about 6 hours into the actual tear down of my 93 and I have the engine out, turbo off and front drive system off.
I'm sure that was NO easy task to accomplish! Way TO GO!
