Dsl_Dog_Treat
Well Goldie has reared up again and sported off another issue today(gender issues I think ;p ). Needing her this weekend is a big issue running 4 days up to Battle Creek for drill/training and low and behold this morning. :***: I got 2 miles down the road and NO steering. I thought she chucked a belt as they were in need of replacing but not this soon. I stopped her and popped the hood to see the belt still turning the pump. No noises from the pump and still had a good fluid level with no leaks. Now I am baffeled and am at a loss as time was of the essence as I got a late start out the door. The Beef was 2 tanks low on fuel and no place was open that early in the am to switch rigs.
I chose to run Goldie on up as I could strong arm the wheel and was hoping the steering would come back. Well further down the road and a hard right turn found that my arms wern't quite strong and had a very difficult time turning the wheel. It seemed to have some resistance fighting back. Well 53 miles later and still no luck. Left her in the lot till chow time and came out with a couple of CM's(construction mechanics) and took a peak. Nothing was found out of the ordinary as the belt was tight and now a little low on fluid as a good share of it was now down the side of the truck.I fired the ole gal up and dang it, the steering was now back to normal and full range both ways. No resistance. :***:
Now the guys think I am full of
and am at a loss.
Only things that we could think of was that a seal has become weak and was allowing fluid to pass by and hydrolocking the pump. No pump noise tho.
The second thought was the gearbox is worn to the point that there was a hangup on the worm gear causing the steering to bind up and not allow full travel even unassisted. Only 169K on the chassis tho and doesn't wander much.
I ran her back the 55 mile trek and no porblems. I swapped the belts off the Beef(keep em clean Mel ;p ) and topped off the fluid and took her for another cruise afterwards and still nothing.
Any thoughts????????
Sorry long winded.
Ron
and am at a loss.Only things that we could think of was that a seal has become weak and was allowing fluid to pass by and hydrolocking the pump. No pump noise tho.
Sorry long winded.
Ron
