6xCrew
Newb
OK so here is the situation. I got this truck. It has issues. The biggest issue right now was its PO. WOW. So seems that something happened in the steering column. Not sure what anymore but the end result was this.
="http://picasaweb.google.com/lh/vi...=5091011713367223809&iid=5091012014014934658"
There is no wiring any more on the column. Then I read this tid-bit of info...
"dont forget that the brakes run throught the turn signal switch, thats what failed for me on my old truck. the brake lights would actaully work if i held up on the switch but if i let off the turn signal switch the brakes would not work."
Well interesting enough my break lights do not work and that is the issue I am trying to fix. I do not have anything on the column though so no way to hold the switch or nuthin.
Can someone conferm for me if this is my issue?
Hope this is not too random. OH and I guess while I am at it I should ask if an 88 2wd column will fit an 86 4wd truck...
Thanks for any help you can give,
Calvin
Calvin
