A DB2 pump is the Stanadyne injection pumps found on our idi motors. The name gets shortened around these parts because most know what is being talked about. You have not asked a dumb question at all. Now if you tried to do a pump replacement and removed the top gear cover, then found the injection pump gear attached to it... Then you made a dumb mistake... Working on these motors is mostly stupid simple but..... If you have never done this work its kinda tuff figureing out some of the right and wrong ways of working on these motors... Usually dumb is not used in this forum... But misinformed or somebody told you this or that id kinda looked at with a smile.... Nobody here will laugh at you but we will laugh with you about things.... I know something about these engines but not everything. Some time back about 3 years ago I needed to turn down my injection pump. Well after I did this the truck smoked worse. It took me about a week to figure out what went wrong... And I know which way to turn the fuel screw in the pump... But I turned it the wrong way... I actually turned it up instead of down... I went over everything I had done and finally remembered which way I turned that small screw... I posted that for a laugh... It was an inlightening moment for me.... Kinda the feeling when you head pops out of the backside about something....
