Ggg
Will a 7.3PSD starter work on a 7.3IDI?
The PSD starter will work. BUT it has its advantages and drawbacks. Advantage...if you have a damaged teeth on the ring gear the PSD starter is good.budtoh3zo said:I dont think it will, in my books they look like to completly diff starters
Ggg said:So I take it, the starter will physically fit, but it spins slower. possibly requiring longer crank time thus leading to possible internal damage due to extended cranking time. Right?
yaric008 said:i thought i remember reading on ebay where the PSD starter had 12 teeth instead of 13.
Yup, it's confirmed, http://cgi.ebay.com/ebaymotors/ws/e...tem=7966811731&category=33576&sspagename=WDVW
12 teeth.
I recall someone once saying that PSD's take a relatively long time to start 'cause the engine won't start until there's enough oil pressure present to make the HEUI injectors work...so the engine has to crank until ol pressure builds up before she'll even light off.jdkline said:Is taht why the PSDs take so much longer to start than an IDI?
