Ole BlackBetty
ok, I have bought 2 starters off amazon, that will not throw the bendics. part Number 17578R is this correct part number for a 1994 7.3T engine?
I need help
I need help
This sounds like the issue. If you're not energizing the signal wire, it is not operating the solenoid which is what throws the bendix.If you are going across to the terminal that goes into the starter that is all it will do; spin it will not throw out the bendix.
You are both correct, I was jumping across both large terminals. Seemmmms like when I over heated my starter it also burnt the signal wire. Thank you for your help.This sounds like the issue. If you're not energizing the signal wire, it is not operating the solenoid which is what throws the bendix.
James
it is definately the wrong starterLook at the starter closely. Is there a spacer on the nose cone? If so remove the spacer and the starter should work. If no spacer than yes you will need a different starter. Sounds like you have one for a powerstroke.
