So I had a problem with getting the truck to start (see the "Thanks for the help" thread) and got that fixed by replacing the glow plugs.
But, while trying to start the truck the last few days on the old glow plugs, I fried the starter. It was a NAPA starter, that was about 2 years old. Not the high speed low drag fancy starters you guys recommend.
A bit of background. I had a diesel leak from the fuel filter that might have reached the starter. In any case, I noticed actual smoke coming from the starter a day before I replaced it, and a couple of the rubber o-rings (gaskets) had even partially come out of the starter, which appeared to be a sign of overheating. Operator error there!
More background... the ring around the flexplate with the teeth for the starter gear to engage has some fairly worn teeth. When I got the truck, sometimes the starter would grind when trying to start the truck. Very loud, very embarrassing in a crowd. When I replaced the starter, that problem went away. I know the teeth were still bad, but it seemed the new starter was able to overcome that problem. (bandaid fix, but cheap)
So I went back to NAPA and got a new rebuilt "premium" version starter and put it in the truck. But now, about 50% of the time when I try to start it, I get a somewhat loud "chunk" noise from the starter. It will "chunk/clunk") a few times, then engage and start fine.
I thought perhaps I'd screwed up the install, so I removed the starter and reinstalled it. While I had the battery cables disconnected, I cleaned all the connections with a wire brush, including were it connects to the starter.
So I'm trying to decide whether or not to replace the solenoid on the firewall. Thinking maybe I fried that too earlier, or go back to NAPA for a new starter.
Except for repeated attempts to start the engine, while getting the "chunk/clunk" noise, I have not abused this starter. No excessively long crank times.
Thoughts?
Try a new solenoid, or starter, or both?
Thanks!
Thoughts?
Thanks!
