Spindle Nut Socket Size?
Here you go.
I got it off for you
chevytaHOE5674
Ontonagon, Mi
If its a Dana 50 then that is the only one I've ever seen or heard of in my 20 years wrenching on these trucks with 19 spline outer shafts.
Went outside and took my Dana 44 hub apart to show you that my spindle nuts are identical to yours and I remove them with the standard 4 prong socket from Napa.
chevytaHOE5674
Ontonagon, Mi
Not only do you have 19 spline shafts, I'll bet you have 48 splines in the hub itself and a Dana 50 should have I think 55 splines.
Like suggested put a tape measure across the face of your lockout hub.
YOU HAVE A DANA 44
IT REQUIRES YOU TO PUSH IN HARD TO DISENGUAGE THE RATCHET LOCKING NUT IN ORDER TO RELEASE AND TURN.
If this is a mix match of parts, my question is, are you 100% sure your four wheel drive worked?
It is a Dana 50 TTB....... And like I said I have physically gotten the sockets and tried....... They did not fit......
3 things...
MOST IMPORTANTLY
Why do you beleive this to be a 50 not a 44. The evidence shown by you ...proper D50 spindle nut sockets do not physically fit.....small hub and 19 spline axle would indicate for all intents and purposes that this is a 44 NOT a 50 as you keep saying. The combined knowledge of the folks on this site would tend to indicate you have 44.
Why do you beleive it to be a 50?
Physically gotten correct sockets and did not fit.....
Those two points indicate that the axle in question is a 44 not a 50 then az well.
PHYSICAL Evidence to indicate axle is a 50 is non existant at this point...therefore it must be a 44 HD
Maybe This will help. A 116 post's and 11 days, unbelievable for a lock nut spanner wrench.
jaed_43725
Need Quad Cab 4x4
Lillington/NC
Except he has a DANA 44 outer spindle and axle and locknut Bill...not a 50
:rotflmao:rotflmao:rotflmao:rotflmao
Except it is a 50, not a 44. The nut is 2.5" outside diameter. If it was a 44 it would be 2 3/8". If you truly knew these setups you would know the sizes. And if you weren't a troll you would have read that I already physically tried the 44 nut, and that it in fact was to small. Just because you think you know this setup does not mean you actually do
What PROOF can you offer to validate you do indeed have a 50
As I previously mentioned the proof put forward indicates a 44
Why do you not measure your hub as asked several times?
PROVE IT A 50 otherwise it is a 44.
jaed_43725
Need Quad Cab 4x4
Lillington/NC
I already measured the spindle nut. It is 2.5". Pretty easy to understand. I actually said this on page 3 or such. And I can't measure the hub because I'm on the other side of North Carolina, where my truck is not. So yes, it is a 50 when the Dana 44 socket physically can not engage the nut inside the hub. Not sure what part of that is hard to understand.
mydixiewrecked
