First you'll have to check that driven gear, IIRC also the drive gear in the t-case. What size tires do you have, 235/75r16?
Edit: Stock size is 235/85r16 = 31.73" diameter
I'm going to guess you have a BW1345 t-case, drive gear should be 8 tooth. Guessing the driven gear is a pink 19 tooth. Plenty of calculators out there. I'll update this post with the link to the one I used and a rough estimate on the new driven gear.
Here's a couple of calculators.
http://jimroal.com/drive.htm
http://www.tciauto.com/tc/speedometer-gear-calculator/
I could be wrong at guessing the numbers of teeth. It's been awhile, but I had a light duty '89 F250 with a 302 as a parts truck a long time ago. Stock tires, BW1345 t-case (currently on Bruiser) and 4.10 gears. Speedo driven gear on the VSS was a pink 19 tooth. Out of stock replacement output shaft drive gears I've found for the BW1345 say 8 tooth, but mark one tooth and count yours to be sure. And here's the site that I get speedo driven gears from.
http://www.transmissioncenter.org/Ford_Speedometer_Gears.htm
