kcdigiacomo
I cannot get my wipers or washer to work. Is there an in-line fuse I might be missing? Backstory, My turn signals were not working and listened to General Mechanic friend swore it was the signal switch, (turns out was just the bulbs), so much for that advice. Anyway I replaced the switch and now NO wipers (even put the old switch back in No wipers/washer. Everything else works, turn signals high beams, 4 ways. Thought maybe motor? replaced,, nothing. I have voltage at the fuse box (lower left of steering column, fuse #2, 30amp). Tested fuse for continuity, good. Switched fuse anyway. Have power at the motor plug pin 1 & 2 with key on #3 is ground from a diagram I found on google. Dumbfounded cannot figure this out, PLEASE help!
