Something Electrical?
kcdigiacomo
Yelm, WA
I cannot get my wipers or washer to work. Is there an in-line fuse I might be missing? Backstory, My turn signals were not working and listened to General Mechanic friend swore it was the signal switch, (turns out was just the bulbs), so much for that advice. Anyway I replaced the switch and now NO wipers (even put the old switch back in No wipers/washer. Everything else works, turn signals high beams, 4 ways. Thought maybe motor? replaced,, nothing. I have voltage at the fuse box (lower left of steering column, fuse #2, 30amp). Tested fuse for continuity, good. Switched fuse anyway. Have power at the motor plug pin 1 & 2 with key on #3 is ground from a diagram I found on google. Dumbfounded cannot figure this out, PLEASE help!
kcdigiacomo
Yelm, WA
79 Jasper does that relay control anything else? will google to see if can find it, thank you
kcdigiacomo
Yelm, WA
So I called O'reilly's auto and they gave me their part number, Holy crap 243.00. Part # F4TF-17D539 is off of the relay itself.
Don't ya just Love it when asked a question about a phantom truck.
Got a Ford DVD for every Ford vehicle from 2000 to 2003 and a complete wiring manual for a 99.5.
kcdigiacomo
Yelm, WA
What year truck?
1995 Ford found one at pick-n-pull for $6. Wish I would have checked here first. Next project is fuel tanks. Having issue with rear tank since lent to a friend and he ran out of fuel. Thinking shower head is clogged or collapsed. Would love recommendation on procedure before tackling this one.
Well, if there's room just pull the sender without dropping the tank. Likely the shower head broke off, sending little pieces into the fuel lines, or got stuck in the selector valve.
bossviking
