some questions with my new 94....
Dieselcrawler
Professional wrench holder
Quakertown Pa
first off, what rear does it have? and what size socket for the spindle nut?
secondly, today for some reason the RR brake started trying to lock up with very little pedal pressure applied. enough that the RABS kicked in. it is only that side. the inside of the tire and lip of the drum are dry so i dont think the wheel seal or wheel cylinder are leaking. just curoius if anyone else has had this happen. after work i am going to climb under and back it off some, maybe it just adjusted itself up tight?
Dieselcrawler
Quakertown Pa
what, nobody wants to answer me now. lol
figured out the brake issue, parking brake cable is stiff.
but still would like to know the info on the rear axle.....
Diesel_brad
Dunce
gilbert pa
Corey, you have aSterling 10.25 I want to say the pinion nut is 1 5/16" but dont quote me. Is you pinion seal leaking?
Dieselcrawler
Quakertown Pa
so the duallies have 10.25 also? hmm.
and not the pinion nut, the spindle nut. but if it is a sterling i am all good, already got the socket for them.
Diesel_brad
Dunce
gilbert pa
Yes. All OBSs got the sterling. F-superdutys got the Dana 80 and the F-350 superdutys got the dana 80.
Why do you need to remove the rear hub?
