chillman88
Central NY
Picked up the Cherokee I got today. Hauling it home on the dolly and I was sitting at a red light when (I couldn't make this up) a newer ford dually with a Cherokee of similar vintage goes through the intersection. WHAT ARE THE ODDS???
Towed her 1000 miles away to our new home since it needed brake lines tires and more than likely shoes & pads.
Bye bye snow, salt and magnesium chloride you won't be missed LOL
Sweet, find me a job down there and the wife and I will come join you lol!
RossCo
Ellensburg, Wa
So not necessarily today but, in the last month.
-Repaired cab electrical short, for courtesy lights and radio batt hook up.
-Installed new radio and 5 1/2 Rockford speakers in doors.
-Installed new brake booster and master cylinder
-Drilled and tapped drain plugs for front and rear riffs
-Updated GP system to solid state 7.3 system
-Updated fuel line from filter to IP pump to AN hose instead of leaking metal line
-Installed LED headlights, instead of old seal beam.
Tomorrow, replace rear wheel seals, bearings, races, and brakes...yaaay
......I think that's all..haha...have fun gents
Macrobb
North Idaho
Nice truck. Why does the drivers door damage from rubbing fender happen often on these trucks?
Sent from my SM-G955U using Tapatalk
I find that frame flex is a big contributor to t.
Not sure what exactly I can do to fix it, but I often have problems opening the door when the front tire on that side is over 6" higher than the rest. So when you have the tire on a big rock or onto a snow berm(and I don't mean a little one either), the fender can flex enough for the clearance to go away.
tke395
