So i got time to mess with it a little
dyoung14
Is getting worn out
spencer,tn
i pulled the filter no black fuel, pretty green so thats good, o-rings should be in good shape.
Next i pulled the valve cover harness connector passenger side closest to the fire wall insantly i smelled burnt wires looked at it and 1 possibly 2 pins are burnt, so how do i fix this? also there is a naked wire that looks like is been looped over or something, but i cant find were it goes:confused:
Double-S-Diesel
parts seller
derry pa
you can get new connecters from ford, u will need gaskest also and probly need ucvh as well.
the bare wire is supposed to be that way.
94f450sd
somewhere,ma
Valve Cover Pigtails with plug and wires, OBS
(Ford) F4TZ-12A342-A
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
dyoung14
Is getting worn out
spencer,tn
(Ford) F4TZ-6584-A
so i need all that? whats that gonna cost?
dyoung14
Is getting worn out
spencer,tn
Coul i start with the plug and pigtail? and just change one thing at a time till its fixed?
Double-S-Diesel
parts seller
derry pa
usually if one side is burnt, the gasket is *****, andn the uvch is also *****
dorman makes a kit that has the pieces cheaper, but in my opinion its junk, had to replace in 1 week, but its cheep
the F7TZ-14489-BA (94-96)
was like 20 bucks for 4
check ebay under texascore they usually have gaskest and ucvh used for a decent price.
Ive also cut the bad plug section out of the gasket and put a good one in and used silicon to seal the gaps
Mutley
Ontario
Git er done right the first time. Every time I cheap out it comes back to bust my balls.
94f450sd
somewhere,ma
well i see the grumps were here :rolleyes:
any way if ya need help without the attitudes shoot me an email F450sprdty at aol.com .or hit me up on superdutydiesel.com same user name.
Yeah, didn't want him to get an information overload. That's why I deleted all my post's.
dyoung14
Is getting worn out
spencer,tn
94f450sd has been the most help to me on this site for psd, along with powerstroke nation they are very helpful, the reason i dont listen to you oldbull is because in everyone of my post you either run me down act like im stupid or a combonation of both and i just will not take information from you i will not look at anypost from you, because im not the kinda person that talks to people that treats them like there stupid, im not stupid, i might be slow sometimes but im not stupid
On your first thread about the PSD I went into great detail telling you what to check for the miss on your engine. You wouldn't continue that first thread, you had to start 2 more threads on the same problem. In subsequent post's by me I gave you the parts numbers and places to buy the parts for repair. I even went into great detail in one post on how to check for codes. I may be mistaken but I and others gave you the same advice before 94f450sd did, which you totally disregarded. You can rest assure that I will not respond to any of your threads in the future. I'm just sorry that I deleted most of my post's so you could go back and read them.
Would you like a little Cheese with your Whine?
kbeck
