Shoutout to Bronco Graveyard
scsmith42
New Hill, NC
I've been having some problems with the clutch in my 1990 F250, and after replacing the clutch master and slave cylinders the problem did not go away. Further diagnosis revealed some movement at the clutch master cylinder, so after researching the issue I discovered the Ford TSB about the cracking firewall.
Bronco Graveyard not only stocked the aftermarket part designed to brace the firewall, they shipped it within 12 hours after receipt of order.
That's great customer service!
www.broncograveyard.com
Scott
They carry some obscure stuff that isn't haven't found anywhere else as well......specifically im thinking of the replacement plastic gliders that go on the arms that lift the back glass on a bronco.....Bronco Graveyard was the ONLY place I found them.
Oiler
