w123suv
When I change the oil I drain the pan and then use a punch to make a hole in the bottom of the filter. As soon as I broke though the metal I got water droplets. I would estimate a teaspoon maybe less came out then just normal black oil. I didn't see anything when I opened the drain valve on the pan.
The water was clear/oily but not green. Radiator is full and I don't see any oil on top of coolant.
I'm inclined to not worry about it and see if it happens again at next oil change. Is condensation possible? Can water get sucked in through the intake in a bad rain?
This is a 92 E350 Van.
Thanks for you opinions.
