RSchanz
I did the clear line trick on my truck for troubleshooting. It's been several years and I still haven't taken it off.
I agree this is likely an air intrusion issue. A relatively easy way to prove this is to remove the fuel filter after the engine has been been sitting for a while. Say, a day or a few. If the fuel level is down about 1/3 from the top, you know for sure diesel is draining back to the tank (or fuel simply ran out).
There was a time when I had hard starting and it turned out to be a weak lift pump. I figure one of the internal valves failed, which allows fuel to drain back, but also made it nearly impossible to prime after the truck was shut off for any length of time. Worse still, if parked pointing uphill. Once I got it running it was usually fine until the next cold start.
It doesn't leak fuel to the ground so if anything it must be draining back. The lift pump is relatively new like 4 years. I don't see any fuel leaking anywhere so I feel like this may be hard to diagnose. I already bypassed the water separator too. Any idea what some other main causes of this could be?
