Well, I'm not sure yet, but I picked this truck up last fall, and we got it running just long enough to get it up onto the flatbed so I could pull it home. Once home(my sisters place about 60 miles from me here) we got it started again to get it off the trailer, and it was bangin' and fartin' and smoking something awful, and then it quit, and wouldn't start again, and then it just seized up.
Sat over the winter, and today I went and decided to start lookin' it over. I thought, well, I'll drain the oil and have a look.
I pulled the plug, and about 2 gallons of nice bright green coolant drained out of the oilpan!!
So, then I put the 15/16ths socket on it, and lo and behold, it bars over just fine. Compresssion and everything.
There's a big puddle of oil in the intake that came from the CDR on the drivers' valve cover through the turbo(I'm talking LOTS) but no oil in the Rad, but I could hear compression gasses gurgling up into the rad as I turned it over.
so, the question was, is it cavitation or maybe head gasket, or cracked head etc. Well, I suspect cavitation, but whatever, doesn't matter, the engine has to come out anyway...
I've got a "built" 6.9 to go in it's place, I just want to get the flexplate and bellhousing adapter to make the 6.9 bolt onto the E4OD off the 7.3.
I imagine I'll eventually tear the thing apart and find out what killed it, but for now, this jury is voting cavitation...
182,000km(110,000mi on this engine)
Zigg
