Seats for Diego
saburai
Hi Gang! I know that there are probably many seat upgrade/replacement threads. I'm just to slammed with life to search them out and read through them to find the information I need. We've got about another month here in Florida before pulling the house back up to the Catskill mountains. The worn out seat is literally kicking my ass! I need to replace it or preferable, both before we pull out. I'm asking for suggestions on what seats to use. I don't necessarily need or want power, I'm fine with manual adjustments. What years and models of trucks would be the easiest swap? My truck is a '90 F 250 XLT with buckets and a center console. I'd like to keep the same layout. Of course, direct replacement would be great, but drill a few holes would be ok too. I just don't have much free time right now...
Thanks all:cheers:
genscripter
Inglewood, CA
If all you care about is getting seats ASAP, just go to your nearest pick-u-part junkyard and find late-80's early-90's Ford trucks, find decent seats, and then buy them.
If used seats don't work for you, then you will need to use the Search feature.
Runningaford
Id/Az
I don't know about seat replacement threads, but I do plan on changing my seats soon. I'm leaning towards using nice comfy RV captain chairs up front; I should be able to knock out whatever fab is necessary for this. The back seat will be tossed. I want to build out a raised platform about 15" high in it's place, and then continue it forward between the front captain chairs. My dogs can ride in this area, I can sleep in this area. Under this platform, will be storage for tools, and fluids; For easier access underneath, I plan on doing 'boat style' pull out plates on top of the platform.
saburai
Thanks! So any late 80's,early 90's (bricknose OBS?) Ford truck or van seats are pretty much a bolt in?
saburai
Thanks Cory! For the other types of seats, what is involved, what modifications are necessary to install them? Obviously I'm talkin similar model year Ford trucks. Also, if it's not a lot of work I'm not opposed to power seats. Lastly, any suggestions?
DougsOBS
Im putting a set of 2015 ram 2500 seats in my dually. Pretty easy to modify I thought
I’ve got a super cab and I pulled the front buckets and center console from a 97 crew cab dually. Bolted right in with no modification, for a $150 can’t complain, just need to get around to pulling the passenger seat and lubing the rails.
saburai
Thanks Wes!
Unless I can find a low mileage wreck, I'm still dealing with 20+ year old seats. Lots of farts:eek:
MtnHaul
California
Since you have a SuperCab you should also be able to use Bronco seats as I think they share the same floor pan. I had Bronco seats/brackets in mine for a while but I got tired of not being able to move the seat forward or backward.
@Thewespaul
Did the brackets from the crewcab bolt in to a SuperCab or did you just pull the seats and then bolt them to your SCab brackets? Seems like I see more crewcabs parted out locally than SCabs.
And I do still have the Bronco seats/brackets if someone nearby wants/needs them. I don't want to deal with shipping. I'm near Santa Cruz, CA
kbeck
