Seats for Diego
Discussion in '6.9L IH & 7.3L IDI Diesels' started by saburai, Apr 15, 2018.
  1. saburai
    saburai Full Access Member
    607
    99
    Mar 15, 2016
    Bokeelia Florida
    Hi Gang! I know that there are probably many seat upgrade/replacement threads. I'm just to slammed with life to search them out and read through them to find the information I need. We've got about another month here in Florida before pulling the house back up to the Catskill mountains. The worn out seat is literally kicking my ass! I need to replace it or preferable, both before we pull out. I'm asking for suggestions on what seats to use. I don't necessarily need or want power, I'm fine with manual adjustments. What years and models of trucks would be the easiest swap? My truck is a '90 F 250 XLT with buckets and a center console. I'd like to keep the same layout. Of course, direct replacement would be great, but drill a few holes would be ok too. I just don't have much free time right now...
    Thanks all:cheers:
  2. genscripter
    genscripter Full Access Member
    189
    63
    Nov 22, 2014
    Inglewood, CA
    If all you care about is getting seats ASAP, just go to your nearest pick-u-part junkyard and find late-80's early-90's Ford trucks, find decent seats, and then buy them.
    If used seats don't work for you, then you will need to use the Search feature.
    saburai likes this.
  3. Runningaford
    Runningaford Full Access Member
    275
    69
    Aug 2, 2015
    Id/Az
    I don't know about seat replacement threads, but I do plan on changing my seats soon. I'm leaning towards using nice comfy RV captain chairs up front; I should be able to knock out whatever fab is necessary for this. The back seat will be tossed. I want to build out a raised platform about 15" high in it's place, and then continue it forward between the front captain chairs. My dogs can ride in this area, I can sleep in this area. Under this platform, will be storage for tools, and fluids; For easier access underneath, I plan on doing 'boat style' pull out plates on top of the platform.
    saburai likes this.
  4. saburai
    607
    99
    Mar 15, 2016
    Bokeelia Florida
    Thanks! So any late 80's,early 90's (bricknose OBS?) Ford truck or van seats are pretty much a bolt in?
  5. Dieselcrawler
    Dieselcrawler i pooped today! Staff Member
    32
    5,158
    370
    Jun 4, 2010
    Quakertown Pa
    For yours being a supercab, only supercab seats will bolt right in. 80-97 years
    saburai likes this.
  6. saburai
    607
    99
    Mar 15, 2016
    Bokeelia Florida
    Thanks Cory! For the other types of seats, what is involved, what modifications are necessary to install them? Obviously I'm talkin similar model year Ford trucks. Also, if it's not a lot of work I'm not opposed to power seats. Lastly, any suggestions?
  7. DougsOBS
    DougsOBS Full Access Member
    88
    41
    Sep 7, 2016
    Im putting a set of 2015 ram 2500 seats in my dually. Pretty easy to modify I thought
    saburai likes this.
  8. DougsOBS
    88
    41
    Sep 7, 2016
    saburai likes this.
  9. Thewespaul
    Thewespaul Supporting Member Supporting Member
    3,189
    1,278
    Jul 27, 2015
    Bulverde, Texas
    I’ve got a super cab and I pulled the front buckets and center console from a 97 crew cab dually. Bolted right in with no modification, for a $150 can’t complain, just need to get around to pulling the passenger seat and lubing the rails.
    saburai likes this.
  10. saburai
    607
    99
    Mar 15, 2016
    Bokeelia Florida
    Those look good! What was necessary to make them work?
  11. saburai
    607
    99
    Mar 15, 2016
    Bokeelia Florida
    Thanks Wes!
    Unless I can find a low mileage wreck, I'm still dealing with 20+ year old seats. Lots of farts:eek:
  12. DougsOBS
    88
    41
    Sep 7, 2016
    Basically cutting the front feet and rewelding them. Im sure if you cant weld you can find a buddy who can.
    Pretty simple fab honestly
    saburai likes this.
  13. MtnHaul
    MtnHaul Supporting Member Supporting Member
    209
    33
    Nov 1, 2014
    California
    Since you have a SuperCab you should also be able to use Bronco seats as I think they share the same floor pan. I had Bronco seats/brackets in mine for a while but I got tired of not being able to move the seat forward or backward.
    @Thewespaul
    Did the brackets from the crewcab bolt in to a SuperCab or did you just pull the seats and then bolt them to your SCab brackets? Seems like I see more crewcabs parted out locally than SCabs.
    And I do still have the Bronco seats/brackets if someone nearby wants/needs them. I don't want to deal with shipping. I'm near Santa Cruz, CA
  14. Thewespaul
    3,189
    1,278
    Jul 27, 2015
    Bulverde, Texas
    I used the bracket from the crew cab, bolted right in
Share This Page
