K locally NAPA and Lordco got no clue *** I are speaking of let alone where to get them.
Anyone???
Anyone???
I have some pm me your address how many do you need?K locally NAPA and Lordco got no clue *** I are speaking of let alone where to get them.
Anyone???
Anyone???
Did you tell the idiots at Napa that you needed the ph test strips that are used with the napacool? They did the same thing to me until I mentioned they are used to test the napacool additive.
PH is not SCA though...I cam get Ph strips ....however my understanding was SCA additive was different.....please correct me if I am wrong
FWIW, the diesel shop nearest to me, don't use the test strips. They were very adamant about them not handling temperature variation very well, and will just not work after a little bit of age due to that. Funny enough, while I was in there, a man came in asking them for test strips, and they went through the diatribe again with him; in their opinion, the rated life of coolant with SCA's 'should work', and when taking the cost of the test strips into play, and them going bad, it would be cheaper to just plan on changing your coolant on time, or to install one of those coolant filters that will keep your SCA's up.
I'd think if you change your antifreeze that doesn't have sca's, you could just base the additive SCA's by volume, or more easier, just use a precharged coolant; like fleetgaurd.
Cookson motors an IH truck dealer is hopefully bringing the correct ones in. They sell single test kit but then I cant test the other folks rigs here who hqve asked.
If someone can assert the napa ones are correct even with exhange they are much less than Cooksons strips.
I wouldn't go to that shop ever again.....
