rhkcommander
I'm embarking on a quest to add a saginaw pump to my truck after the stock pump puked its guts all over my driveway... Maybe we can make this a tech article if not. I'm sure I will have some questions too
The Saginaw 6244 pump that is adapted to C-2 mounting is not available anymore - it was a direct drop in that used an adapter to convert the 4-bolt saginaw to the 3-bolt C-2 pump mounts.
Or these
http://www.borgeson.com/xcart/catal...pgrade_Kits_for_Fords-orderby_0-p-1-c-86.html
http://www.ebay.com/itm/429-460-FOR...BRACKET-KIT-BBF-BILLET-ALUMINUM-/121173865082
PSC makes an adapter (PSC-MB03K) to convert the saginaw to C-1 and C-2 pump styles
http://www.pscmotorsports.com/ford-5-0-saginaw-pump-adapter-bracket.html
Apparently you may have to grind the old mount to make it all fit together...
Or you can get real creative and weld one up like oldblue05
http://www.oilburners.net/forums/showthread.php?50330-Saginaw-powersteering-pump-upgrade
I tried a few local yards and had zero luck with finding any van-style brackets that originally held saginaws but would drop in. I found one that could work with a lot of spacers but I thought toying around with that sounds like a nightmare. I bought it anyway so I would have a core and some metal to cut and weld on if necessary. I also needed the pulley and this one is a 2-belt.
I bought a NAPA refurb canned ham style saginaw. Brought it home and held it up to my original power steering bracket to see if I could find a way to make it work. The saginaw is much narrower than the C-2 was, and the "right side" is raised compared to the "left side" (if the pulley is the front and reservoir cap is the top)... So I opted to make the right side work with the C-2 pump mounting bracket.
Tools Used:
The bracket is aluminum, easy to work on but it will gum up tools. The C-2 mounts only use 3 bolts, the saginaw can use up to 4. You can line up the bottom right bolt hole on the saginaw with the bottom right hole on the bracket, and right above the top right bolt hole is a recess in the aluminum pump bracket. Its almost like it was meant to be. So i took some paper and marked the two holes and then held them against the bracket and transferred the spot for the second hole. Drilled it with small bits and worked my way up to 3/8", making sure the alignment was good - it came out perfect!
After that I lined up the two holes and found out where things would get in the way. I had to grind a good bit off the top of the bracket to get it to clear, and a little bit on one side. Nothing 10 minutes of grinding and repolishing with the wire wheel cant handle. I also trimmed a little off of the saginaw pump, mostly the casting junk. Looking back now I may not have needed to grind the bracket as much as I did because I might need to use spacers between the bracket and pump - oops. The reason I want to keep the stock bracket is it will be universal with C-2 or saginaw, and it seems cheaper and easier than fabbing a full-custom one / waiting for adapters or brackets in the mail.
In the morning I am planning on making a small steel adapter to hook up the other two bolt holes to the mount, maybe tapping it so it can bolt together but I havent decided yet how I want to do it. I may cut the bracket off the old saginaw i got at the junk yard. Gotta pull the pulley off, I figure to reinstall it on the new one I can just find a bolt that threads into the shaft and use a nut with washers to drive it on
I've heard conflicting information regarding the high pressure line - someone said theirs fit just fine and others have said I will need the ford van one. Everyone has said it will fit the stock ford steering gear though.
Pictures to come in the morning
Or these
Tools Used:
- Grinder stand w/ wire wheel
- dremel with cut off wheels and grinder
- sharpee & paper (for marking where to drill and grind)
- drill & drill bits
