ManBearPig
I bought a 91 7.3 with a "factory" ATS turbo a few weeks ago. I bought it to pull our 9k pound travel trailer (near the truck's comfort level, I know) and haven't really had a chance to put it to work much yet. I bought the truck thinking it was a complete, mechanically sound project but soon found it was really closer to 80% there (for my standards, at least). I did take the rig for a test pull right after I got it, and found the water temp seemed to run pretty hot. It didn't have a "real" water temp gauge but during the short pull, it ran at the "L" in normal which I figured must be pretty warm. So I ordered a water temp gauge, 4-core aluminum Champion radiator, and a new Motorcraft thermostat. The radiator and stat got here before the temp gauge, so I unfortunately don't have any "before" data to compare to. I haven't pulled the load again yet, but I'm a little concerned about what I'm seeing during regular driving. Now granted, I've run the truck hard trying to get it warm even unloaded, but I was hoping I wouldn't be able to. Running 75 on the interstate in the hill country I have seen just over 210*. This is around 2500 RPM and it takes some boost to keep the truck at that speed. 5 psi or so. I realize 210* is very safe....but this is unloaded. If it runs anything more than 20* warmer than this when pulling, that's really about as warm as I want to see.
So my questions are...
I mounted the gauge sender in place of the overtemp sensor. While I realize that isn't as ideal as mounting it in place of the OEM gauge....I figured it would be pretty good. Does this spot show warmer than the OEM gauge location? Cooler? By how much?
How much warmer can I expect to see temps when pulling heavy vs normal driving? 10*? 20*? 30* warmer?
Thanks for the info, as always.
