I pulled my sway bar off a while back because frankly I wasn't sure if it was doing any good.
I've decided I should put it back in but the bushings were well overdue for replacement. End links are expensive but bushings are cheap.
Parts to make a puller. 3/8 bolt probably 4" long with a nut, a 1" pipe nipple and some washers.
Puller installed.
Crank it down tight then put it in the vise and hit the puller bolt with a punch and a 3# "motivator" until it pops the rest of the way out.
Pulled out.
Puller installed.
Pulled out.
