commonsthor
how do you remove front axle ujoint chilton doesnt explain it to well. really could use some help .... thanks
commonsthor said:its the pass. outer . so i just remove the steering knuckle and pull the axle out of the pumpkin? thanks for info mel
Why was pulling the spindle so difficult? I pulled mine in August to replace the inner bearings (and have been kicking myself ever since for not replacing the U-joints and the balljoints, but $$ was tight), and my spindles came off without too much of a fuss. After undoing the nuts that hold them on, I sprayed the area with something (can't remember what, but I think it was either PB Blaster, WD-40 or brake cleaner). I then took a small chisel and lightly tapped it into the space where the spindle mates with the knuckle. The spindle then came off with very little difficulty... it was downright anticlimactic.John Haggerty said:I know that I had to remove the spindle to remove the shaft with joints on my truck (a 89). Removing the spindle was though. I had to make a puller to get the spindle off.
I'm guessing that your spindle was rusted in place?[/QUOTE said:Rusted, at least! Couldn't get one to break with a chisel (one did). I made a puller that consisted of a plate with the shaft diameter bored thru it and four standoffs. I used the spindle nut to jack.
