Replace blown 94 id I turbo
Cranky
Apollo,pa.
Newbie here.Sure is a lot of info on here. Anyway bought a 94 standard cab 4x4 nice body etc.Any way engine blown,oil high on dip stick owner said used a lot of oil before garage towed it. My question is I have another rusted 1990 7.3 n!a with 60,000 miles. Can I use this motor in the 94 using turbo from it on the 60,000 mi. 7.3Also does it have any electronics I need to worry about? Any info on this would be greatly appreciated.
Hydro-idi
Lodi, California
All of the components should transfer over without a problem. As long as your sure the 94 engine is in fact an idi, and not a 94.5 power stroke.
Cranky
Apollo,pa.
Yes it is a idi turbo not powerstroke. Bought the truck for 1300 bucks. Thanks for the input. I will take a picture of it when I get it.200,000 mi. On it but you could eat off it that clean new tires and loaded,guess he just have up on it!
Cranky
Apollo,pa.
Yes I will. Garage where truck was towed said truck used 2 gal. Of oil in 300 mi.,oil to top of dipstick.Ran but missed.Would only start with diesel poured into intake.About 200,000 on motor.Might be toast.Truck not here yet so we'll see!
Randy Bush
Great Falls, Mt
Sounds like might be rebuildable yet, just wore out real bad.
Isaac Ristow
Somerset Wisconsin
the flywheel or flex plate will not transfer over because of different balancing between factory turbo and NA also you'll need to make a custom turbo oil feed line as the idi-t has 1/4 npt and the idi na has 1/8th npt. otherwise everything will bolt up you'll have to switch to your serp setup
Randy Bush
Great Falls, Mt
If both have manual or automatic transmission , pull the NA out put in good truck and slap the turbo on it.
austin92
Brazil. IN
Pouring diesel down the intake is probably what blew it
Cranky
Apollo,pa.
Well donor n/a motor is auto tranny. New 94 turbo motor is 5 speed so guess I'll need another flywheel on the n/a motor I'm putting in right?Then use turbo on the n/a
Isaac Ristow
Somerset Wisconsin
Yes you'll need a smf clutch kit for a 88-92 7.3 NA motor. the turbo and everything else is bolt up but the flywheel between turbo and NA has different balancing
DavidS
Norfolk, VA
The crank is also different between turbo and NA, it is balanced differently to account for the heavier rods and pistons in the turbo. I just went through this on my truck.
dieselmainiac
