david85
This could be a long read but it will have plenty of photos for those who want to skim.
Some back ground:
Back when I first got my IDI, it wasn't rare, pretty nor special, so when the factory AC couldn't be revived, I hacked in an FS10 compressor from a later model truck. It was cheap 2nd hand and I had time to make the brackets and weld the pulley on as shown here:
When combined with Duracool, and later Red Tek refrigerant it worked pretty good for many years but eventually failed again.
Now that the "Tin Bashing" thread is just about complete, I'm coming full circle on some of the things that I wasn't able to fix properly way back when. Due to the amazing summer we've been having up here on the BC south coast, working AC is pretty high on the list.
So now comes the task of putting back the original setup with the correct FS6 compressor. Only problem is I scrapped the brackets when I did the FS10 mod. Like I said, the truck wasn't special back then...at least I didn't think so and certainly none of the local wreckers do either. Even 7.3 strokers are getting rare.
So next place was Ebay. Yup, found two listings.
1st listing: Had the exact bracket I needed for $100USD + shipping. That's a bit steep.
2nd listing: Had ALL the AC Compressor Brackets for $75USD. Reasonable, but the seller refuses to ship to Canada.
After looking at the two listings I decide to steal their photos. Why, you ask? Because I have access to a CNC and I feel like being stubborn. So here's what I ended up with:
Since the bracket is small enough to barely fit on a 8.5 x 11 sheet of paper, making some test templates was easy. 2nd try gave me a pattern that matched the compressor mounts perfectly.
Next came a metal template on the CNC, which was cut from 1/16" aluminum sheet. One slight adjustment to one of the holes and its good to go. Out comes the 1/2" aluminum plate:
Some back ground:
