6 Nebraska IDIs
- Joined
- May 27, 2007
- Posts
- 4,247
- Reaction score
- 15
Yepper! The brand new rear we just installed in my dads old daily driver less than a year ago locked up today. It had brake problems a few weeks ago so we pulled the thing apart after noticing the axle seal was leaking. So we serviced the whole thing, drained it, and found grit in the main housing so we flushed everything out with solvent and filled it back up with premium oil. We also installed new axle bearings at the same time, which is funny because this is what went bad. We havent torn it apart yet but we tracked it down to the drivers side hub which was nearly glowing hot and would barely spin after an hour of cooling down. I dont know what would have caused the bearings on that hub to lock up but they did.
We were hauling a new washer/dyer pair home with it today and getting off the freeway we felt it bog a little, and my dad was like WTH, then it did a bigger bog and started bucking, and then all of a sudden it started squeaking like a rod bearing was dry. So we pulled over thinking it was the engine, but after close examination we could find no evidence anything was wrong with the engine and started off down the road again to see if it would do it again and it sure did not a quarter mile down the road, except this time it locked up so bad before we could pull over, it pulled us all the way into the LH shoulder
and my dad and to fight it over to the correct shoulder.
Lucky we were only about a mile from my brother and he came and got us and took us to my dads work where we borrowed the Mack Rollback and loaded it up and hauled it home.
Oh GOODY! Im looking forward to tomorrow!
