RDT into exhaust
no mufflers
rhode island
I have been thinking about this quite a bit, my question is, is there a way to plumb a RDT into the exhaust so it almost makes a suction on the crank case? or at least wont make any pressure on the crank case. I have seen this on some gassers with headers. I like the RDT but sometimes it can be a little obnoxious.
You can. (In theory) I've never seen anyone do it and stick with it.
Most go to a filtered setup. You can build your own, or buy a pro vent.
ive done this, and loved it. ran the truck for 6 months without oil in my exhaust.
i welded up a pipe in my downpipe to accept a checkvalve, so it cant blow back.
welded the pipe in at a 60* angle for that venturi effect.
i loved it.
but, the downpipe isnt the place to do it.
do the same after the downpipe, makes install easier..
no mufflers
rhode island
my RDT runs down next to the radius arm bracket. I have dual exhaust that runs on the outside of the frame about 2 feet past the RDT. if I ran a longer RDT and put it in the exhaust so it would be with the exhaust flow, would that work? will I still need a checkvalve?
no mufflers
rhode island
i loved it.
did you check to see if it made a suction effect?
nope, i saw a very very slight haze out of the exhaust at operating temperature.
no smoke coming out of oil fill while running.
was good enough for me.
Clb
Another old truck
nannyfornia
Top fuelers run this setup, check summit or speedway?
Well for a idi. Lol
But I bet there's a bit more exhaust velocity at 8000 RPM.
I'm not saying don't do it at all, I'd rather use a separator setup though.
no mufflers
rhode island
Well for a idi. Lol
what do you mean by a separator?
Yep. That's just one of the pre-made kits.
You can build your own with parts from tractor supply. (Or other ag stores)
Staff online
